メインコンテンツにスキップ
Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement
必要な工具と部品
  1. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Earmuff: 手順 1、 1の画像 1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 2、 1の画像 1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement, Adjustable Sliding Hinges: 手順 3、 1の画像 1
    • Remove the four 8mm screws on the ear cup using a #000 Phillips screwdriver to reveal the motherboard.
  4. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 4、 3の画像 1 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 4、 3の画像 2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 4、 3の画像 3
    • On one half of the ear cup that was previously removed, there will be located a motherboard. On the other half there will be a coupler holding the cup to the hinge and allowing it to move in a 360 degree manner. Remove this coupler by unscrewing the 10mm screw with the same #000 Phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 5、 2の画像 1 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 5、 2の画像 2
    • On the leather part of the headset, four 6mm Torx screws need to be removed using a T6H Torx screwdriver.
  6. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 6、 2の画像 1 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 6、 2の画像 2
    • On the other side of the 6mm torx screws, there is a nameplate that needs to be pried off using a pry tool.
  7. Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 7、 3の画像 1 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 7、 3の画像 2 Sennheiser Momentum Wireless M2 AEBT Adjustable Sliding Hinges Replacement: 手順 7、 3の画像 3
    • Steps 1-4 need to be repeated for the other ear cup.
終わりに
The hinges must be removed from BOTH sides of the headphones for even one side to come out. They are attached together.
作成者
3人の作成者と共同で作成されました。
welsayed
メンバー登録日: 09/08/23
319 ポイント
3のガイドは作成済み
チーム
University of New Orleans, Team 5-2, McDonald Fall 2023 University of New Orleans, Team 5-2, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S5G2
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 32
今までの合計 229
