はじめに
This repair guide wil give a walk through on how to replace the power LED in a Sega Genesis.
パーツ
パーツは指定されていません。
  1. Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Flip the Sega Genesis upright.
    • Flip the Sega Genesis upright.
  3. Gently lift the top casing.
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Bend out the LED leads into vertical positions.
    • Bend out the LED leads into vertical positions.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. Slide the LED wire apparatus off the lead pins.
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  7. Separate the main board from the outer case.
    • Separate the main board from the outer case.
  8. Remove plastic "Power / On" cover by pushing tabs together.
    • Remove plastic "Power / On" cover by pushing tabs together.
  9. Pull "Power / On" cover away from the console cover.
    • Pull "Power / On" cover away from the console cover.
  10. From the outside of the top cover, remove LED.
    • From the outside of the top cover, remove LED.
  11. Insert new LED (Click here to buy LED.)
  12. Re-insert "Power / On" cover until it clicks into place.
    • Re-insert "Power / On" cover until it clicks into place.
まとめ
5 の人々がこのガイドを完成させました。
Anthony Porchia
メンバー登録日: 2010年10月11日
341 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S3G29
4 メンバー
5のガイドは作成済み
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - 返信
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani -
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - 返信
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
https://youtu.be/HJPyhfy56a0
thebigtoe_98 -
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 98
今までの合計 11,924
