メインコンテンツにスキップ
Sega Dreamcast Logic Board Replacement
必要な工具と部品
  1. Sega Dreamcast Logic Board Replacement, Expansion Bay: 手順 1、 2の画像 1 Sega Dreamcast Logic Board Replacement, Expansion Bay: 手順 1、 2の画像 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Logic Board Replacement: 手順 2、 3の画像 1 Sega Dreamcast Logic Board Replacement: 手順 2、 3の画像 2 Sega Dreamcast Logic Board Replacement: 手順 2、 3の画像 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Logic Board Replacement, Top Cover: 手順 3、 1の画像 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Logic Board Replacement: 手順 4、 1の画像 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 手順 5、 2の画像 1 Sega Dreamcast Logic Board Replacement, Power Block (Power Supply): 手順 5、 2の画像 2
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Sega Dreamcast Logic Board Replacement: 手順 6、 1の画像 1
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Sega Dreamcast Logic Board Replacement: 手順 7、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 7、 2の画像 2
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Sega Dreamcast Logic Board Replacement: 手順 8、 1の画像 1
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
  9. Sega Dreamcast Logic Board Replacement, Controller Port: 手順 9、 2の画像 1 Sega Dreamcast Logic Board Replacement, Controller Port: 手順 9、 2の画像 2
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
    Note that on some Dreamcasts the power board (on the left) overhangs slightly over the controller board, meaning one must also remove the power board at this stage. This is relatively straightforward, fortunately. Remove a screw each at the top left of the power board and at the bottom left of the power board, remove the white clip at the top left, pop out the white clip on the left of the power board and lift the power board out from the front where you have the white block containing eight pins that connect the power board to the sub board. Then proceed per the rest of this guide. Hope this helps.
    JP Asher - 返信
  10. Sega Dreamcast Logic Board Replacement: 手順 10、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 10、 2の画像 2
    • Remove the four 14mm Philips #02 screws located on the controller board.
  11. Sega Dreamcast Logic Board Replacement: 手順 11、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 11、 2の画像 2
    • Disconnect the white fan header from the controller port.
    Perhaps list the battery type an battery holders that allow for easy replacement in the future?
    Brett Kampf - 返信
  12. Sega Dreamcast Logic Board Replacement: 手順 12、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 12、 2の画像 2
    • Remove the controller board by lifting it up from the controller port.
  13. Sega Dreamcast Logic Board Replacement, GD-ROM: 手順 13、 2の画像 1 Sega Dreamcast Logic Board Replacement, GD-ROM: 手順 13、 2の画像 2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  14. Sega Dreamcast Logic Board Replacement: 手順 14、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 14、 2の画像 2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  15. Sega Dreamcast Logic Board Replacement: 手順 15、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 15、 2の画像 2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  16. Sega Dreamcast Logic Board Replacement: 手順 16、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 16、 2の画像 2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  17. Sega Dreamcast Logic Board Replacement, Fan: 手順 17、 1の画像 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  18. Sega Dreamcast Logic Board Replacement: 手順 18、 1の画像 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  19. Sega Dreamcast Logic Board Replacement: 手順 19、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 19、 2の画像 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  20. Sega Dreamcast Logic Board Replacement, Logic Board: 手順 20、 3の画像 1 Sega Dreamcast Logic Board Replacement, Logic Board: 手順 20、 3の画像 2 Sega Dreamcast Logic Board Replacement, Logic Board: 手順 20、 3の画像 3
    • Remove the five 10mm Philips #02 screws from left side of the logic board cover.
    • Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
  21. Sega Dreamcast Logic Board Replacement: 手順 21、 3の画像 1 Sega Dreamcast Logic Board Replacement: 手順 21、 3の画像 2 Sega Dreamcast Logic Board Replacement: 手順 21、 3の画像 3
    • Lift the metal cover from the console.
  22. Sega Dreamcast Logic Board Replacement: 手順 22、 2の画像 1 Sega Dreamcast Logic Board Replacement: 手順 22、 2の画像 2
    • Before handing the logic board, you may want to use a grounding strap to protect the device from static charge. If you do not have a grounding strip, you may ground yourself by touching a large metallic object.
    • Remove the logic board and set the logic board on an anti-static surface.
終わりに
21 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
wkwong
メンバー登録日: 11/14/09
517 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G1
5 メンバー
21のガイドは作成済み
コメント 1 件
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
Nickolas Wilcox - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 38
過去 30 日: 204
今までの合計 23,063
