はじめに
A guide to remove the intake fan from the Sega Dreamcast.
Verify that the console is disconnected from the AC outlet before you begin.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
コメントを追加する
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
コメントを追加する
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
コメントを追加する
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
コメントを追加する
  • Remove the white fan header by gently pulling it away from from the controller port.
  • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
コメントを追加する
  • Remove the two 8.5mm Philips #00 screws from the fan bracket.
コメントを追加する
  • Remove the two 17.5mm Philips #00 screws from the fan bracket.
  • Remove the fan from the bracket.
コメントを追加する
まとめ
2 の人々がこのガイドを完成させました。
wkwong
メンバー登録日: 2009年11月14日
414 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G1
5 メンバー
23のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 6,072
