はじめに
Before attempting this guide complete the CD Tray Removal Guide.
必要な工具と部品
Using a Phillips head screwdriver remove six screws from the bottom of the console.
The six screws are marked.
Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
The three screws are shown on the diagram.
Remove the two bronze screws from the metal plate with a medium Phillips head screwdriver.
The screws are marked on the diagram.
Carefully lift the metal plate up to expose the motherboard.
There is a wire strip running through the metal plate that is soldered to motherboard and power supply board. The plate cannot be completely removed. Do NOT force plate upwards. All the ribbon cables can be safely unplugged by simply pulling them out of their slots.
5 の人々がこのガイドを完成させました。
