はじめに
I repaired a couple of screen replacements for the Samsung Note 20
I did one that needed a back glass and one that did not.
Created a custom back glass to troll my older brother for not having a case on a brand new phone. The replacement screens had not even been created yet until now we waited for 3 weeks!
必要な工具と部品
ビデオの概要
On this Note 20 the OLED is clearly broken and has a crack on the side.
The back has no damage to it so apply heat.
Start from the bottom straight up and down push tool in until you hit the frame you will hear a sound
Slide tool at angle stop at the curve
After loosening the bottom pull tool out.
Now pry with your fingers and pull up with suction cup.
While sticking splicer on curved edge side slowly working wiggling down the curve edge
Lift and wiggle the back glass off
Remove 6 PH000 Screws from the wireless charging pad covering the battery connection.
Disconnect wireless coil from connections with plastic spudger
Use spudger at top on the metal squeezing it under the top of the wireless charging pad bracket.
Lift and wiggle slowly the charging pad off while locating the battery connection
Battery Connection!!
Remove 4 PH000 Screws to the ear speaker bracket.
Also disconnect this connection!
Make sure its disconnected
Disconnect all yellow boxed connections!
Remove the 2 PH000 Screws holding the camera
Lift mainboard with spudger from ear speaker goin down using the frame as a leveler
Front Camera Location
Use straight edge blade at bottom of camera to break it loose. You can actually pull the glue/adhesive out it will come out in one chunk.
Lift camera out slowly
Remove 2 black PH000 Screws on top right lifting flex out.
Remove 2 PH000 Screws on Bottom right lift flex out.
During this repair on the black Note 20 Ultra I noticed the screen looked refurbished had issues with screws being stripped I did some serious work drilling into the phone. Which is not included in this guide.
Before I worked on the phone that had the stripping screw issue I already had worked on the phone which I made a video and had not issues with screws stripping the phone I did the picture guide was clearly refurbished straight talk phone.
11 の人々がこのガイドを完成させました。
8 件のコメント
I did the repair and ran into issues with the REAR camera. I retraced all my hardware. its all connected. the selfie cam works. nothing got disconnected when I removed the mother board. i’ve tried to reset app cache
help plz
Abe Arslan - 返信
Do you have all the screws back in with the speakers and wireless charger coil on the phone?
Stow -
Rear camera hmm did you try repeating the connection did the cameras work before repair?
Thanks for the effort here with the guide. Unless I am missing something (lol) where is the part of the screen replacement (by screen = the display screen, right?) I see the back replacement here. You do mention the OLED screen being broken at the beginning but the guide is for the back replacement, right? (not as title suggests ‘screen replacement) Sorry maybe am wrong here.
He transfered anything from the original phone to the new sreen/frame assembly.
