メインコンテンツにスキップ
Screen Assembly Removal
必要な工具と部品
  1. Screen Assembly Removal, Turn off the watch: 手順 1、 2の画像 1 Screen Assembly Removal, Turn off the watch: 手順 1、 2の画像 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Screen Assembly Removal, Remove the rear screws: 手順 2、 1の画像 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Screen Assembly Removal, Separate the back cover from the housing: 手順 3、 3の画像 1 Screen Assembly Removal, Separate the back cover from the housing: 手順 3、 3の画像 2 Screen Assembly Removal, Separate the back cover from the housing: 手順 3、 3の画像 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Screen Assembly Removal, Disconnect the sensor array: 手順 4、 2の画像 1 Screen Assembly Removal, Disconnect the sensor array: 手順 4、 2の画像 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Screen Assembly Removal, Remove the back cover: 手順 5、 1の画像 1
    • Remove the back cover.
  6. Screen Assembly Removal, Disconnect the display and the mic array: 手順 6、 3の画像 1 Screen Assembly Removal, Disconnect the display and the mic array: 手順 6、 3の画像 2 Screen Assembly Removal, Disconnect the display and the mic array: 手順 6、 3の画像 3
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Screen Assembly Removal, Undo the mic tape: 手順 7、 3の画像 1 Screen Assembly Removal, Undo the mic tape: 手順 7、 3の画像 2 Screen Assembly Removal, Undo the mic tape: 手順 7、 3の画像 3
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Screen Assembly Removal, Lift the core assembly: 手順 8、 2の画像 1 Screen Assembly Removal, Lift the core assembly: 手順 8、 2の画像 2
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Screen Assembly Removal, Remove the core assembly: 手順 9、 3の画像 1 Screen Assembly Removal, Remove the core assembly: 手順 9、 3の画像 2 Screen Assembly Removal, Remove the core assembly: 手順 9、 3の画像 3
    • Lift out and remove the core assembly.
  10. Screen Assembly Removal, Loosen the mic: 手順 10、 2の画像 1 Screen Assembly Removal, Loosen the mic: 手順 10、 2の画像 2
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
  11. Screen Assembly Removal, Free the barometric sensor: 手順 11、 2の画像 1 Screen Assembly Removal, Free the barometric sensor: 手順 11、 2の画像 2
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Screen Assembly Removal, Remove the mic array: 手順 12、 1の画像 1
    • Carefully remove the microphone and barometric sensor array from the frame.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
129,498 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,145のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 19
今までの合計 698
