メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Schwinn Tourist Inner Tube Replacement
必要な工具と部品
  1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: 手順 1、 1の画像 1
    • Flip the bicycle upside down.
    • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
    FixBotに聞いてみる
    コメントを追加
  2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: 手順 2、 1の画像 1
    • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
    • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
    FixBotに聞いてみる
    コメントを追加
  3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 手順 3、 2の画像 1 Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: 手順 3、 2の画像 2
    • Push the quick release lever outwards towards your body.
    • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
    FixBotに聞いてみる
    コメントを追加
  4. Schwinn Tourist Inner Tube Replacement, Remove Tire: 手順 4、 1の画像 1
    • Lift the tire to remove it from the bicycle.
    FixBotに聞いてみる
    コメントを追加
  5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: 手順 5、 1の画像 1
    • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
    • Attach the other end of the tire lever to the nearest spoke on the rim.
    FixBotに聞いてみる
    コメントを追加
  6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: 手順 6、 1の画像 1
    • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
    FixBotに聞いてみる
    コメントを追加
  7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 手順 7、 1の画像 1
    • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
    FixBotに聞いてみる
    コメントを追加
  8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: 手順 8、 1の画像 1
    • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
    FixBotに聞いてみる
    コメントを追加
  9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: 手順 9、 1の画像 1
    • Push the valve stem upwards through the hole in the rim.
    FixBotに聞いてみる
    コメントを追加
  10. Schwinn Tourist Inner Tube Replacement, Finished: 手順 10、 1の画像 1
    • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Quandre Mebane
メンバー登録日: 10/07/14
149 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-22, Donnelly Fall 2014 USF Tampa, Team 1-22, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G22
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 42
今までの合計 5,600
