パーツ
パーツは必要ありません。
  1. Place the monitor face down.
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Remove two 11.5mm screws with a  #2 Phillips screwdriver.
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Using a  #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. Pry the monitor using the plastic opening tool to release the clips holding the cover on. There are four clips on each side, four on the top, and one on the bottom. You may hear a loud snapping noise when releasing the clips.  Do not be alarmed, it is natural.
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  6. Using the  #2 Phillips screwdriver, remove the one 6mm screw. Unplug the indicated cable by pulling on the base.
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  7. Disconnect the two connectors to the speakers by gently pulling on the hard plastic straight up.
    • Disconnect the two connectors to the speakers by gently pulling on the hard plastic straight up.
  8. Carefully peel the tape from the board.
    • Carefully peel the tape from the board.
  9. Flip the monitor so the screen is facing you.
    • Flip the monitor so the screen is facing you.
    • Using Phillips #2 screwdriver remove the four 6.25 mm screws securing the speakers:
  10. Carefully lift the speakers up.
    • Carefully lift the speakers up.
まとめ
ある他の人がこのガイドを完成しました。
Xenia Leon Rodriguez
メンバー登録日: 2012年09月26日
37 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G56
5 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 319
