メインコンテンツにスキップ
Sceptre X9 Komodo VII Power Supply Unit Replacement
必要な工具と部品
  1. Sceptre X9 Komodo VII Power Supply Unit Replacement, Stand: 手順 1、 1の画像 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 2、 1の画像 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Power Supply Unit Replacement, Board Cover: 手順 3、 1の画像 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 4、 3の画像 1 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 4、 3の画像 2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 4、 3の画像 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 5、 2の画像 1 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 5、 2の画像 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Power Supply Unit Replacement, Power Supply Unit: 手順 6、 1の画像 1
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  7. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 7、 3の画像 1 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 7、 3の画像 2 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 7、 3の画像 3
    • Unplug the seven connections from the power supply unit by gently pulling on them.
  8. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 8、 1の画像 1
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
  9. Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 9、 2の画像 1 Sceptre X9 Komodo VII Power Supply Unit Replacement: 手順 9、 2の画像 2
    • Lift the power supply unit straight up to remove it from the back panel.
終わりに
作成者
5人の作成者と共同で作成されました。
Jose Carrillo
メンバー登録日: 09/26/12
23 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G56
5 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 664
