はじめに
When your light bulb wears out and your Scentsy warmer doesn’t melt the wax as well as they are supposed to, then it’s time to replace the light bulb. It depends on the warmer that you have, different Scentsy warmers take light bulbs with different wattage. Using a light bulb with a lower wattage can result in the wax not being melted all the way. Using a light bulb with a higher wattage can be dangerous and potentially damage your warmer. Therefore, I recommend you use a light bulb with the correct wattage.
必要な工具と部品
Once complete, the warmer should turn on and melt the wax completely, creating a good fragrance in your household.
2 の人々がこのガイドを完成させました。
