メインコンテンツにスキップ
Sanyo-PM 8200 Keypad Replacement
必要な工具と部品
  1. Sanyo-PM 8200 Keypad Replacement, Power Off Phone: 手順 1、 1の画像 1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Keypad Replacement, Remove Old Battery: 手順 2、 1の画像 1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Keypad Replacement, Back Casing: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Keypad Replacement: 手順 4、 1の画像 1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Keypad Replacement: 手順 5、 2の画像 1 Sanyo-PM 8200 Keypad Replacement: 手順 5、 2の画像 2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Keypad Replacement, Keypad: 手順 6、 2の画像 1 Sanyo-PM 8200 Keypad Replacement, Keypad: 手順 6、 2の画像 2
    • Remove the camera and call keys from the side of the phone where the antenna is located.
    • Remove the Readylink and volume control buttons from the other side of the phone.
  7. Sanyo-PM 8200 Keypad Replacement: 手順 7、 1の画像 1
    • Place the plastic opening tool underneath the motherboard and gently lift up.
    • Be careful not to damage the flex cable ribbon connecting the motherboard to the device.
  8. Sanyo-PM 8200 Keypad Replacement: 手順 8、 3の画像 1 Sanyo-PM 8200 Keypad Replacement: 手順 8、 3の画像 2 Sanyo-PM 8200 Keypad Replacement: 手順 8、 3の画像 3
    • Flip open the phone to reveal the keypad.
    • Place the plastic opening tool underneath the keypad and gently push the keypad towards the motherboard.
    • Remove the keypad.
終わりに
作成者
2人の作成者と共同で作成されました。
Cassandra Stavros
メンバー登録日: 10/07/14
28 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-6, Leahy Fall 2014 USF Tampa, Team 1-6, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S1G6
6 メンバー
10のガイドは作成済み
コメント 1 件
In almost all flip phones, there’s a flex cable ribbon that connects the motherboard to the display side of the phone. It is permanently attached to the display side and plugs into the motherboard. As there are anywhere from 16 to 50 connections in the cable, I recommend being careful NOT to unplug it…aligning it for plugging it back in properly can be tricky!
Kevin Wade - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 273
