メインコンテンツにスキップ
Sanyo VPC-X1200 Main Board Replacement
必要な工具と部品
  1. Sanyo VPC-X1200 Main Board Replacement, Back Case: 手順 1、 3の画像 1 Sanyo VPC-X1200 Main Board Replacement, Back Case: 手順 1、 3の画像 2 Sanyo VPC-X1200 Main Board Replacement, Back Case: 手順 1、 3の画像 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 Main Board Replacement: 手順 2、 1の画像 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 Main Board Replacement, LCD Screen: 手順 3、 2の画像 1 Sanyo VPC-X1200 Main Board Replacement, LCD Screen: 手順 3、 2の画像 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 Main Board Replacement: 手順 4、 2の画像 1 Sanyo VPC-X1200 Main Board Replacement: 手順 4、 2の画像 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 Main Board Replacement, Button Plate: 手順 5、 2の画像 1 Sanyo VPC-X1200 Main Board Replacement, Button Plate: 手順 5、 2の画像 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 Main Board Replacement: 手順 6、 2の画像 1 Sanyo VPC-X1200 Main Board Replacement: 手順 6、 2の画像 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 Main Board Replacement, Lens Unit: 手順 7、 1の画像 1
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 Main Board Replacement: 手順 8、 2の画像 1 Sanyo VPC-X1200 Main Board Replacement: 手順 8、 2の画像 2
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 Main Board Replacement: 手順 9、 1の画像 1
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 手順 10、 3の画像 1 Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 手順 10、 3の画像 2 Sanyo VPC-X1200 Main Board Replacement, Flash Lens: 手順 10、 3の画像 3
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  11. Sanyo VPC-X1200 Main Board Replacement: 手順 11、 1の画像 1
    • Remove round silver bezel from the front of the camera.
  12. Sanyo VPC-X1200 Main Board Replacement: 手順 12、 1の画像 1
    • Remove the two screws on the bottom of the front cover.
  13. Sanyo VPC-X1200 Main Board Replacement: 手順 13、 1の画像 1
    • Remove tripod mount.
  14. Sanyo VPC-X1200 Main Board Replacement: 手順 14、 1の画像 1
    • Carefully lift off the front cover plate of the camera.
  15. Sanyo VPC-X1200 Main Board Replacement: 手順 15、 1の画像 1
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
  16. Sanyo VPC-X1200 Main Board Replacement, Main Board: 手順 16、 3の画像 1 Sanyo VPC-X1200 Main Board Replacement, Main Board: 手順 16、 3の画像 2 Sanyo VPC-X1200 Main Board Replacement, Main Board: 手順 16、 3の画像 3
    • Push out pin that holds the door hinge together
    • Pull out the pin. Be careful to keep track of the spring and black spacer.
    • Set the battery door aside
終わりに
作成者
4人の作成者と共同で作成されました。
Anthony Giardina
メンバー登録日: 04/19/10
20 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 7-10, Maness Spring 2010 Cal Poly, Team 7-10, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G10
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 2,251
