メインコンテンツにスキップ
Sanyo VPC-T700 LCD Screen Replacement
必要な工具と部品
  1. Sanyo VPC-T700 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 1 Sanyo VPC-T700 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 2 Sanyo VPC-T700 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 3
    • Cameras powers on and the broken LCD becomes immediately evident.
    • Remove the battery
    • Remove the camera strap
  2. Sanyo VPC-T700 LCD Screen Replacement: 手順 2、 3の画像 1 Sanyo VPC-T700 LCD Screen Replacement: 手順 2、 3の画像 2 Sanyo VPC-T700 LCD Screen Replacement: 手順 2、 3の画像 3
    • Remove the four screws on the right side of the camera
    • Remove the two screws on the left side.
    • remove the four screws on the bottom of the camera.
    • The two screws on the thread for a tripod are longer than the others, keep those separated.
  3. Sanyo VPC-T700 LCD Screen Replacement: 手順 3、 3の画像 1 Sanyo VPC-T700 LCD Screen Replacement: 手順 3、 3の画像 2 Sanyo VPC-T700 LCD Screen Replacement: 手順 3、 3の画像 3
    • Here is a look at the screws from the camera. The two screws from the tripod thread are the longest.
    • Start splitting the housing with either an opening tool or your fingernails. The housing does not require a lot of force and will easily unsnap.
    • The front cover seems to be easiest and will come off first
  4. Sanyo VPC-T700 LCD Screen Replacement: 手順 4、 3の画像 1 Sanyo VPC-T700 LCD Screen Replacement: 手順 4、 3の画像 2 Sanyo VPC-T700 LCD Screen Replacement: 手順 4、 3の画像 3
    • The rear cover can now be easily removed. The LCD is sitting in a frame without fasteners. It will just lift up, however, there will be a piece of insulating material that is separating the back of the LCD from the logic board. Remove this after the removal of the LCD from the frame. Do not try to remove the LCD from the PCB yet.
    • Open the ribbon cable connector by pulling the white clasp gently up.
    • Remove the old LCD.
  5. Sanyo VPC-T700 LCD Screen Replacement: 手順 5、 2の画像 1 Sanyo VPC-T700 LCD Screen Replacement: 手順 5、 2の画像 2
    • Here is the new LCD. Note the protective cover. Remove that cover by pulling on the green tab after installing the LCD to the PCB.
    • After reassembling your camera, hopefully it will look like this.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
oldturkey03
メンバー登録日: 09/29/10
781,658 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
32 メンバー
531のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,291
