メインコンテンツにスキップ
Sanyo VPC S1275 LCD Screen Replacement
必要な工具と部品
  1. Sanyo VPC S1275 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 LCD Screen Replacement, Case: 手順 3、 3の画像 1 Sanyo VPC S1275 LCD Screen Replacement, Case: 手順 3、 3の画像 2 Sanyo VPC S1275 LCD Screen Replacement, Case: 手順 3、 3の画像 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 LCD Screen Replacement: 手順 4、 2の画像 1 Sanyo VPC S1275 LCD Screen Replacement: 手順 4、 2の画像 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 LCD Screen Replacement: 手順 5、 3の画像 1 Sanyo VPC S1275 LCD Screen Replacement: 手順 5、 3の画像 2 Sanyo VPC S1275 LCD Screen Replacement: 手順 5、 3の画像 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 LCD Screen Replacement: 手順 6、 1の画像 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 LCD Screen Replacement: 手順 7、 1の画像 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 1 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  9. Sanyo VPC S1275 LCD Screen Replacement: 手順 9、 1の画像 1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
終わりに
作成者
6人の作成者と共同で作成されました。
Evan Perez
メンバー登録日: 04/15/10
19 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G24
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 3,075
