Carefully pry the screen protector off the phone using the flat end of the spudger.
This will require a bit of force as the back of the screen protector is lined with an adhesive material.
Once free from the adhesive, pull the screen protector away from the phone.
Use the spudger to pry off the front case from the left and right sides of the device.
Once it has popped off, pull the casing apart with fingers.
Using a spudger, remove the ribbon connection of the camera from the adhesive that attaches it to the device.
Grab the camera using fingers and remove it from the phone case.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
