メインコンテンツにスキップ
Sanyo Katana Camera Replacement
必要な工具と部品
  1. Sanyo Katana Camera Replacement, Screen Protector: 手順 1、 2の画像 1 Sanyo Katana Camera Replacement, Screen Protector: 手順 1、 2の画像 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Camera Replacement: 手順 2、 2の画像 1 Sanyo Katana Camera Replacement: 手順 2、 2の画像 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Camera Replacement: 手順 3、 2の画像 1 Sanyo Katana Camera Replacement: 手順 3、 2の画像 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Camera Replacement, Front Case: 手順 4、 3の画像 1 Sanyo Katana Camera Replacement, Front Case: 手順 4、 3の画像 2 Sanyo Katana Camera Replacement, Front Case: 手順 4、 3の画像 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Camera Replacement, Camera: 手順 5、 3の画像 1 Sanyo Katana Camera Replacement, Camera: 手順 5、 3の画像 2 Sanyo Katana Camera Replacement, Camera: 手順 5、 3の画像 3
    • Use a Tri-wing Y0 screwdriver to remove the 4.4mm screw.
    • Use fingers to remove the strip.
  6. Sanyo Katana Camera Replacement: 手順 6、 3の画像 1 Sanyo Katana Camera Replacement: 手順 6、 3の画像 2 Sanyo Katana Camera Replacement: 手順 6、 3の画像 3
    • Detach the ribbon connections underneath the green connector strip and remove them from the device. This will reveal the camera.
  7. Sanyo Katana Camera Replacement: 手順 7、 3の画像 1 Sanyo Katana Camera Replacement: 手順 7、 3の画像 2 Sanyo Katana Camera Replacement: 手順 7、 3の画像 3
    • Using a spudger, remove the ribbon connection of the camera from the adhesive that attaches it to the device.
    • Grab the camera using fingers and remove it from the phone case.
終わりに
作成者
5人の作成者と共同で作成されました。
Preston
メンバー登録日: 03/11/13
216 ポイント
5のガイドは作成済み
チーム
Clemson, Team 12-1, Benson Spring 2013 Clemson, Team 12-1, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S12G1
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 309
