メインコンテンツにスキップ
Sansa e260R Memory Board Replacement
必要な工具と部品
  1. Sansa e260R Memory Board Replacement, Rear Case: 手順 1、 1の画像 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Memory Board Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Memory Board Replacement: 手順 3、 1の画像 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Memory Board Replacement, Battery: 手順 4、 1の画像 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Memory Board Replacement, Front Panel: 手順 5、 1の画像 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Memory Board Replacement: 手順 6、 1の画像 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Memory Board Replacement: 手順 7、 2の画像 1 Sansa e260R Memory Board Replacement: 手順 7、 2の画像 2
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Memory Board Replacement, Memory Board: 手順 8、 2の画像 1 Sansa e260R Memory Board Replacement, Memory Board: 手順 8、 2の画像 2
    • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
    • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
  9. Sansa e260R Memory Board Replacement: 手順 9、 1の画像 1
    • Pull the bottom of the motherboard up and then out.
  10. Sansa e260R Memory Board Replacement: 手順 10、 1の画像 1
    • On the back of the motherboard, there is a rectangle of rubber.
    • Peel the rectangle off slowly.
  11. Sansa e260R Memory Board Replacement: 手順 11、 1の画像 1
    • Under the rubber rectangle, there is a strip of black tape.
    • Peel the tape off about halfway so that it is no longer attached to the memory board.
  12. Sansa e260R Memory Board Replacement: 手順 12、 1の画像 1
    • Carefully peel the memory board away from the rest of the motherboard
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
JenniferW
メンバー登録日: 01/31/12
176 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-15, Maness Winter 2012 Cal Poly, Team 8-15, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G15
5 メンバー
5のガイドは作成済み
コメント 1 件
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 2,559
