ツール
工具は必要ありません。
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
    • Lift off the metal plate by pulling it towards you.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
    • Slide the belt off of the circular knob.
    • Pull brush roller out and detach the belt off the brush roller.
まとめ
Caycie Pascual
メンバー登録日: 2012年09月26日
1 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G58
5 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 831
