メインコンテンツにスキップ
Sandisk Sansa m230 Series mp3 player Microphone Replacement
必要な工具と部品
  1. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Sandisk Sansa m230 Series mp3 player Teardown: 手順 1、 1の画像 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 2、 1の画像 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 3、 1の画像 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 4、 1の画像 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 5、 1の画像 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 6、 1の画像 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Microphone: 手順 7、 1の画像 1
    • Locate microphone on motherboard.
  8. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 8、 1の画像 1
    • Find where microphone is connected to motherboard via solder.
  9. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 9、 2の画像 1 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 9、 2の画像 2
    • Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 10、 1の画像 1
    • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
    • When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  11. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 11、 2の画像 1 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 11、 2の画像 2
    • Remove the faulty microphone as you heat and melt the soldering points.
  12. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 12、 1の画像 1
    • Replace the faulty microphone with a new one in working order.
  13. Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 13、 2の画像 1 Sandisk Sansa m230 Series mp3 player Microphone Replacement: 手順 13、 2の画像 2
    • With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
    • Give the new solder time to cool and harden.
終わりに
作成者
4人の作成者と共同で作成されました。
James Thorne
メンバー登録日: 11/05/13
638 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 1-8, Shastany Fall 2013 UMass Dartmouth, Team 1-8, Shastany Fall 2013人のメンバー
UMASSD-SHASTANY-F13S1G8
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 496
