メインコンテンツにスキップ
Sandisk Sansa m230 Series mp3 player Hold Switch Replacement
必要な工具と部品
  1. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement, Sandisk Sansa m230 Series mp3 player Teardown: 手順 1、 1の画像 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 2、 1の画像 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 3、 1の画像 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 4、 1の画像 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 5、 1の画像 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 6、 1の画像 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement, Hold Switch: 手順 7、 1の画像 1
    • Locate the hold switch on the motherboard.
  8. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 8、 1の画像 1
    • Locate the hold switch connection to the motherboard via soldered connections.
  9. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 9、 1の画像 1
    • Use the soldering iron to liquefy the solder connecting the hold switch to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 10、 1の画像 1
    • The solder and soldering iron will be very hot. Use caution to avoid getting burned.
    • Be sure to always rest the hot end of the soldering iron on a metal stand to prevent accidental burns.
  11. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 11、 1の画像 1
    • Liquefy the solder on each contact and remove each contact individually.
    • With the contacts removed, lift the switch off the motherboard.
  12. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 12、 1の画像 1
    • Replace the faulty hold switch with a new one.
  13. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 13、 1の画像 1
    • There may be some solder in the way of the hold switch's metal contacts. If this occurs simply melt or remove the solder to create room for the contacts.
  14. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: 手順 14、 1の画像 1
    • With the new hold switch in place, use the soldering iron to solder the contacts between the motherboard and hold switch.
    • Be sure to allow the new solder to cool and harden.
終わりに
作成者
7人の作成者と共同で作成されました。
James Thorne
メンバー登録日: 11/05/13
638 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 1-8, Shastany Fall 2013 UMass Dartmouth, Team 1-8, Shastany Fall 2013人のメンバー
UMASSD-SHASTANY-F13S1G8
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 14
今までの合計 714
