メインコンテンツにスキップ
SanDisk Sansa C250 Front Case Cover Replacement
必要な工具と部品
  1. SanDisk Sansa C250 Front Case Cover Replacement, Battery Cover: 手順 1、 1の画像 1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Front Case Cover Replacement: 手順 2、 1の画像 1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Front Case Cover Replacement, Battery: 手順 3、 1の画像 1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Front Case Cover Replacement: 手順 4、 1の画像 1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Front Case Cover Replacement: 手順 5、 1の画像 1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Front Case Cover Replacement, Rear Case Cover: 手順 6、 1の画像 1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Front Case Cover Replacement: 手順 7、 1の画像 1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Front Case Cover Replacement: 手順 8、 1の画像 1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Front Case Cover Replacement: 手順 9、 1の画像 1
    • The rear case cover can now be separated from the device.
  10. SanDisk Sansa C250 Front Case Cover Replacement, Front Case Cover: 手順 10、 1の画像 1
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  11. SanDisk Sansa C250 Front Case Cover Replacement: 手順 11、 1の画像 1
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  12. SanDisk Sansa C250 Front Case Cover Replacement: 手順 12、 1の画像 1
    • Open the case cover starting on the side most distance from the buttons.
  13. SanDisk Sansa C250 Front Case Cover Replacement: 手順 13、 1の画像 1
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  14. SanDisk Sansa C250 Front Case Cover Replacement: 手順 14、 1の画像 1
    • You can now safely remove the front case cover from the device.
終わりに
作成者
6人の作成者と共同で作成されました。
Nicolas Coffey
メンバー登録日: 01/27/12
43 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 3-30, Amido Winter 2012 Cal Poly, Team 3-30, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G30
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,351
