はじめに
Follow the steps in the guide to replace the display or broken glass.
After these essential steps you can proceed to disassemble the device for other repairs.
Heat the display edges adequately at 80 degrees Celsius (176°F), then proceed to detach the display by inserting the flat opening tools between the display glass and the frame.
Be careful not to rip the flat cables that lie underneath the lower part of the phone, near the keys
Be careful not to rip the display flat connectors that lie underneath the upper part of the phone
Note: the screen is also attached in the middle with an "L" shaped and "i" shaped strong glue. Make sure u heat that up too. Its explained in the next step! Beware...
Has been specified in step 4, the L-shaped pink strip must be warm and carefully detached
Smilzo -
To assemble the device, follow these instructions in reverse order.
38 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
14 件のコメント
slt le problem que j ait un sm- g800f copy
c est pas originale et j arive pas a trouver l aficheur qui ce convien a lui
j besoin de votre aide pour avoir un aficheur pour tlphon portable sm-g800f fcc id:a3lsmg800f made korea by samsung
essayer d'expliquer avec des mots corrects, parce que le traducteur ne comprend pas ce que vous dites
Smilzo -
Not sure, but it sounds like he's looking for a display to fit a Samsung Galaxy S5 Mini (sm- g800f) that may or may not be a fake? There are a lot of shorthand and typos in there though...
Hi!
I have a broken glasfront and would like to repair it,
I have found spare parts on amazon but from the tutorials I have the feeling I cant change the glas front alone or can I?
My display has no damage whatsoever.
Just wanted to make sure its possible before buying the spare part
Does a Samsung Galaxy S5 LCD + Digitizer work as a replacement for the S5 Neo? Everything looks the same, but I'm trying to connect the ribbon cable and it's not snapping in easily. I fear forcing it could damage it. Any idea?
S5 and S5 Neo have different plug size. You cannot swap between.
Hi! Good guide very usefull, only confusing thing i found is the way the pictures are displayed at step 4. The way the phone opens from the top on the first one and then from the bottom on the second lead me to think it was from the top both times. Beside that very helpfull.
hello, I tried to open it a bit 'from all sides, starting from the top and then laterally and below, because of the parts glued in the center I did not understand how to move, finally opening the outline you can lift it from below to not damage the cables of display. Now that you know how it's done, you can move as you see fit to remove the display without breaking down
Smilzo -
Is it possible to remove a perfectly good screen off of an already functional phone without damaging the ribbons/LCD and glass to use on another Galaxy 5 neo? Both being the exact same models of phones, of coarse!
