メインコンテンツにスキップ
Samsung YP-P3 Buttons Replacement
必要な工具と部品
  1. Samsung YP-P3 Buttons Replacement, Case Backplate: 手順 1、 1の画像 1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Buttons Replacement: 手順 2、 1の画像 1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Buttons Replacement: 手順 3、 2の画像 1 Samsung YP-P3 Buttons Replacement: 手順 3、 2の画像 2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
  4. Samsung YP-P3 Buttons Replacement, Printed Circuit Board: 手順 4、 3の画像 1 Samsung YP-P3 Buttons Replacement, Printed Circuit Board: 手順 4、 3の画像 2 Samsung YP-P3 Buttons Replacement, Printed Circuit Board: 手順 4、 3の画像 3
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
  5. Samsung YP-P3 Buttons Replacement: 手順 5、 2の画像 1 Samsung YP-P3 Buttons Replacement: 手順 5、 2の画像 2
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
  6. Samsung YP-P3 Buttons Replacement: 手順 6、 1の画像 1
    • Disconnect the battery connector, and then lift the circuit board up.
  7. Samsung YP-P3 Buttons Replacement: 手順 7、 1の画像 1
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
  8. Samsung YP-P3 Buttons Replacement, Battery: 手順 8、 1の画像 1
    • Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
  9. Samsung YP-P3 Buttons Replacement, Touch Screen: 手順 9、 3の画像 1 Samsung YP-P3 Buttons Replacement, Touch Screen: 手順 9、 3の画像 2 Samsung YP-P3 Buttons Replacement, Touch Screen: 手順 9、 3の画像 3
    • Remove the six screws (Phillips #000, 2.3 mm long) holding the screen frame to the front of the case. As the picture shows, one of them is hidden under the black speaker/rumble assembly.
  10. Samsung YP-P3 Buttons Replacement: 手順 10、 2の画像 1 Samsung YP-P3 Buttons Replacement: 手順 10、 2の画像 2
    • To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger.
    • The assembly is glued to the back of the screen, so the assembly may not move at first. Be patient and careful. Do not pry too hard, or you may break the assembly.
  11. Samsung YP-P3 Buttons Replacement: 手順 11、 1の画像 1
    • Lift the screen out from the case.
  12. Samsung YP-P3 Buttons Replacement, Buttons: 手順 12、 2の画像 1 Samsung YP-P3 Buttons Replacement, Buttons: 手順 12、 2の画像 2
    • The buttons, built-in speaker, and rumble device are all contained in a black plastic assembly. This assembly simply snaps into place at the top of the case. Lift up gently to remove it from its place.
終わりに
作成者
2人の作成者と共同で作成されました。
Andrew Groeneveld
メンバー登録日: 02/24/14
567 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 5-3, Lauer Spring 2014 Michigan Tech, Team 5-3, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G3
4 メンバー
6のガイドは作成済み
コメント 1 件
This is terrific, but who makes a 3”, 272x480 pixel lcd screen and/or touchpanel for the samsung? Is this the same screen hardware as on the P2?
Kevin Moorman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 533
