メインコンテンツにスキップ
Samsung WB350F Screen Replacement
必要な工具と部品
  1. Samsung WB350F Screen Replacement, Rear Case: 手順 1、 3の画像 1 Samsung WB350F Screen Replacement, Rear Case: 手順 1、 3の画像 2 Samsung WB350F Screen Replacement, Rear Case: 手順 1、 3の画像 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Screen Replacement: 手順 2、 3の画像 1 Samsung WB350F Screen Replacement: 手順 2、 3の画像 2 Samsung WB350F Screen Replacement: 手順 2、 3の画像 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Screen Replacement: 手順 3、 3の画像 1 Samsung WB350F Screen Replacement: 手順 3、 3の画像 2 Samsung WB350F Screen Replacement: 手順 3、 3の画像 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Screen Replacement: 手順 4、 1の画像 1
    • Remove the plastic casing, exposing the inner workings of the camera.
  5. Samsung WB350F Screen Replacement, Screen: 手順 5、 2の画像 1 Samsung WB350F Screen Replacement, Screen: 手順 5、 2の画像 2
    • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
    • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
  6. Samsung WB350F Screen Replacement: 手順 6、 1の画像 1
    • Move the menu button panel to the right as well as the screen.
    • Be careful because each are connected to the camera by a ribbon.
  7. Samsung WB350F Screen Replacement: 手順 7、 1の画像 1
    • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
  8. Samsung WB350F Screen Replacement: 手順 8、 2の画像 1 Samsung WB350F Screen Replacement: 手順 8、 2の画像 2
    • Remove the silver panel.
  9. Samsung WB350F Screen Replacement: 手順 9、 2の画像 1 Samsung WB350F Screen Replacement: 手順 9、 2の画像 2
    • Flip the screen back over.
    • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
  10. Samsung WB350F Screen Replacement: 手順 10、 2の画像 1 Samsung WB350F Screen Replacement: 手順 10、 2の画像 2
    • Carefully detach both ribbons by gently pulling one at a time.
    • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
    • Be sure to pull gently as you do not want to break either ribbon.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Casey Bernier
メンバー登録日: 03/04/16
131 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G2
4 メンバー
8のガイドは作成済み
コメント 1 件
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,384
