メインコンテンツにスキップ
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: 手順 1、 3の画像 1 Samsung WB350F Battery Replacement, Battery: 手順 1、 3の画像 2 Samsung WB350F Battery Replacement, Battery: 手順 1、 3の画像 3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: 手順 2、 1の画像 1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
    My battery will not come out. I can push down on it but it doesn't move. The blue clip holding battery moves but battery is stuck in place.
    pritchardb789 - 返信
    I’ve got this same problem. Does anyone have a solution please? Short of destroying the camera to get the battery out, I’m stuck!
    Hazel Doherty - 返信
終わりに
作成者
5人の作成者と共同で作成されました。
Taylor Joubert
メンバー登録日: 03/04/16
273 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G2
4 メンバー
8のガイドは作成済み
コメント 1 件
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 36
今までの合計 1,878
