メインコンテンツにスキップ
Samsung WB2200F LCD Screen Replacement
必要な工具と部品
  1. Samsung WB2200F LCD Screen Replacement, Face-plate: 手順 1、 3の画像 1 Samsung WB2200F LCD Screen Replacement, Face-plate: 手順 1、 3の画像 2 Samsung WB2200F LCD Screen Replacement, Face-plate: 手順 1、 3の画像 3
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  2. Samsung WB2200F LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  3. Samsung WB2200F LCD Screen Replacement: 手順 3、 1の画像 1
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  4. Samsung WB2200F LCD Screen Replacement, LCD Screen: 手順 4、 1の画像 1
    • Using the the screw driver with the JIS size 000 head, unscrew each and every 6mm screw surrounding the LCD screen after taking off the face plate.
  5. Samsung WB2200F LCD Screen Replacement: 手順 5、 1の画像 1
    • The LCD screen has two layers; the screen on top and the metallic screen protector it lays in. Make sure to take out the screw to the right of both layers that link them together.
  6. Samsung WB2200F LCD Screen Replacement: 手順 6、 1の画像 1
    • Disconnect the faulty screen from the metallic compartment as well as the motherboard of the camera.
  7. Samsung WB2200F LCD Screen Replacement: 手順 7、 1の画像 1
    • Place the new screen inside the metallic compartment and make sure it fits perfectly on each side.
  8. Samsung WB2200F LCD Screen Replacement: 手順 8、 1の画像 1
    • Proceed to insert and tighten screws around the screen which has been placed inside its metallic compartment. Be sure to screw in the main 0.4cm screw that connects both the LCD screen and metallic screen together first.
終わりに
作成者
2人の作成者と共同で作成されました。
Rudolf Boampong
メンバー登録日: 03/04/16
195 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 321
