メインコンテンツにスキップ
Samsung WB150F Lens Assembly Replacement
必要な工具と部品
  1. Samsung WB150F Lens Assembly Replacement, Battery: 手順 1、 1の画像 1
    • The location of the battery compartment can be found on the underside of the camera.
  2. Samsung WB150F Lens Assembly Replacement: 手順 2、 2の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 2、 2の画像 2
    • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
  3. Samsung WB150F Lens Assembly Replacement, LCD Screen: 手順 3、 1の画像 1
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  4. Samsung WB150F Lens Assembly Replacement: 手順 4、 3の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 4、 3の画像 2 Samsung WB150F Lens Assembly Replacement: 手順 4、 3の画像 3
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  5. Samsung WB150F Lens Assembly Replacement: 手順 5、 1の画像 1
    • Your camera should now look like the camera in the photo.
  6. Samsung WB150F Lens Assembly Replacement: 手順 6、 2の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 6、 2の画像 2
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  7. Samsung WB150F Lens Assembly Replacement: 手順 7、 3の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 7、 3の画像 2 Samsung WB150F Lens Assembly Replacement: 手順 7、 3の画像 3
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  8. Samsung WB150F Lens Assembly Replacement: 手順 8、 3の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 8、 3の画像 2 Samsung WB150F Lens Assembly Replacement: 手順 8、 3の画像 3
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
  9. Samsung WB150F Lens Assembly Replacement, Motherboard: 手順 9、 3の画像 1 Samsung WB150F Lens Assembly Replacement, Motherboard: 手順 9、 3の画像 2 Samsung WB150F Lens Assembly Replacement, Motherboard: 手順 9、 3の画像 3
    • Disconnect the ribbon from the flash assembly.
    • Disconnect two ribbons from the lens assembly as shown in the second picture.
    • Disconnect the ground wire from the motherboard as shown in the third picture.
  10. Samsung WB150F Lens Assembly Replacement: 手順 10、 2の画像 1 Samsung WB150F Lens Assembly Replacement: 手順 10、 2の画像 2
    • Remove the motherboard from the camera housing.
  11. Samsung WB150F Lens Assembly Replacement, Lens Assembly: 手順 11、 1の画像 1
    • Lens assembly freely detaches from housing once both ribbons are detached from the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Wyatt Turner
メンバー登録日: 04/12/22
265 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 7-7, Beck Spring 2022 IUPUI, Team 7-7, Beck Spring 2022人のメンバー
IUPUI-BECK-S22S7G7
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 349
