メインコンテンツにスキップ
Samsung WB150F LCD Screen Replacement
必要な工具と部品
  1. Samsung WB150F LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  2. Samsung WB150F LCD Screen Replacement: 手順 2、 3の画像 1 Samsung WB150F LCD Screen Replacement: 手順 2、 3の画像 2 Samsung WB150F LCD Screen Replacement: 手順 2、 3の画像 3
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  3. Samsung WB150F LCD Screen Replacement: 手順 3、 1の画像 1
    • Your camera should now look like the camera in the photo.
  4. Samsung WB150F LCD Screen Replacement: 手順 4、 2の画像 1 Samsung WB150F LCD Screen Replacement: 手順 4、 2の画像 2
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  5. Samsung WB150F LCD Screen Replacement: 手順 5、 3の画像 1 Samsung WB150F LCD Screen Replacement: 手順 5、 3の画像 2 Samsung WB150F LCD Screen Replacement: 手順 5、 3の画像 3
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  6. Samsung WB150F LCD Screen Replacement: 手順 6、 3の画像 1 Samsung WB150F LCD Screen Replacement: 手順 6、 3の画像 2 Samsung WB150F LCD Screen Replacement: 手順 6、 3の画像 3
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
終わりに
To reassemble your device, follow steps 1-5 in reverse order.
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Patrick Gouveia
メンバー登録日: 03/24/15
112 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015人のメンバー
UMASSD-VIJAYBHASKAR-S15S4G4
3 メンバー
6のガイドは作成済み
コメント 1 件
This guide is excellent. I bought a used wb150f which powered up, but did not respond to the control buttons on the back. Looking at these great high-res pix, I could see there was a mating connector between the button board and the main board, so I hoped I could re-seat that connector and it would start working. Opening it up was easy, but step 4 required me to separate the case slightly at the edges before I could get a gap to pry into. When I got the case off, I could see that the entire connector had come off the button board, and to fix it would be impossible due to the tiny pitch of the pins. Still, without this guide I would never have known for sure the issue. Back to Goodwill you go!
Steve Duncan - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 14
今までの合計 1,688
