はじめに
Use this guide to remove the motherboard of your device.
必要な工具と部品
On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
The motherboard is in the middle of the device and has all wires and connections of the device components running to it. The fan identified as fan A is located on top of it and must be removed first.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
