はじめに
This guide will help you replace the processor cooling fan for the Samsung UBD-K8500. A faulty cooling fan can lead to an overheating device causing hardware and short circuit problems.
必要な工具と部品
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
もう少しです!
終わりに
