はじめに
This guide will help you replace the circuit board for the Samsung UBD-K8500. If your circuit board becomes faulty after exposure to heat, an impact, power surges or overloads, access this guide to replace the defective circuit board. A fragmented connection from the motherboard to the daughter board may cause glitches and errors in reading discs.
必要な工具と部品
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Using your fingers, carefully pinch the clipping part of the four connectors and gently pull them out of their sockets.
ある他の人がこのガイドを完成しました。
