メインコンテンツにスキップ
Samsung U28E510 Low Voltage Display Signal Board Replacement
必要な工具と部品
  1. Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 手順 1、 3の画像 1 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 手順 1、 3の画像 2 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 手順 1、 3の画像 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 2、 2の画像 1 Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 2、 2の画像 2
    • Flip the monitor over so that it is face down.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Low Voltage Display Signal Board.
  3. Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 3、 2の画像 1 Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 3、 2の画像 2
    • Remove the 4 holding screws using a #0 Phillips screwdriver.
    • Lift the cover to expose the LVDS Board while taking care to prevent removal of the white fogged plastic cover. This plastic cover keeps the wire ribbons safe from accidental damage.
  4. Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 4、 2の画像 1 Samsung U28E510 Low Voltage Display Signal Board Replacement: 手順 4、 2の画像 2
    • Disconnect the input signal ribbon cable from the top of the board.
    • Disconnect the output signal ribbon cables by using a plastic sprudger to lift the connection lock.
    • Remove and replace the LVDS Board.
終わりに
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around the monitor.
作成者
2人の作成者と共同で作成されました。
Raymundo Calderon-Robles
メンバー登録日: 01/22/18
306 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S11G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 18
今までの合計 998
