メインコンテンツにスキップ
Samsung U28E510 Jog Button Replacement
必要な工具と部品
  1. Samsung U28E510 Jog Button Replacement, Jog Button: 手順 1、 3の画像 1 Samsung U28E510 Jog Button Replacement, Jog Button: 手順 1、 3の画像 2 Samsung U28E510 Jog Button Replacement, Jog Button: 手順 1、 3の画像 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: 手順 2、 2の画像 1 Samsung U28E510 Jog Button Replacement: 手順 2、 2の画像 2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: 手順 3、 1の画像 1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
終わりに
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jake Ritter
メンバー登録日: 01/22/18
106 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S11G1
4 メンバー
6のガイドは作成済み
5 件のコメント
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - 返信
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - 返信
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - 返信
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 85
今までの合計 6,523
