必要な工具と部品
Use a heat gun or similar tool to heat around the edge of the glass.
Use a suction cup to lift the glass up and insert a opening tool in between the glass and frame:
Work around the glass to loosen the adhesive securing the glass.
Take care when sliding the tool in front of the camera, there is also alight sensor that is hidden underneath the glass
It may be possibel to pull the adhesive strip out from the glass.
Carefully lift the display up from the right side to expose the cables underneath.
The display cable can be seen as marked in the red box.
Disconnect the cable and remvoe the old display.
Clean any remaining glass or adhesive from the frame.
To replace the display follow the steps in reverse order. Test the display before securing it to the frame.
4 の人々がこのガイドを完成させました。
