メインコンテンツにスキップ
Samsung TFT Color YP-T7J The Screen Replacement
必要な工具と部品
  1. Samsung TFT Color YP-T7J The Screen Replacement, The Back Cover: 手順 1、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement, The Back Cover: 手順 1、 2の画像 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Screen Replacement: 手順 2、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 2、 2の画像 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Screen Replacement: 手順 3、 3の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 3、 3の画像 2 Samsung TFT Color YP-T7J The Screen Replacement: 手順 3、 3の画像 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Screen Replacement, The Battery: 手順 4、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement, The Battery: 手順 4、 2の画像 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Screen Replacement: 手順 5、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 5、 2の画像 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 1 Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 2 Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 手順 6、 3の画像 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J The Screen Replacement, The Front Cover: 手順 7、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement, The Front Cover: 手順 7、 2の画像 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J The Screen Replacement: 手順 8、 3の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 8、 3の画像 2 Samsung TFT Color YP-T7J The Screen Replacement: 手順 8、 3の画像 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J The Screen Replacement: 手順 9、 1の画像 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J The Screen Replacement: 手順 10、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 10、 2の画像 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J The Screen Replacement, The Screen: 手順 11、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement, The Screen: 手順 11、 2の画像 2
    • Place the pry tool between the plastic housing around the LCD screen, and the mother board.
    • Gently separate the screen housing from the mother board
    • CAUTION: The screen is still attached to the mother board via another electric ribbon.
  12. Samsung TFT Color YP-T7J The Screen Replacement: 手順 12、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 12、 2の画像 2
    • Using a plastic pry tool to flip up the lip, which connects the electric ribbon to the mother board.
  13. Samsung TFT Color YP-T7J The Screen Replacement: 手順 13、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 13、 2の画像 2
    • Place the pry tool between the LCD screen and the white housing unit
    • Gently separate the two.
  14. Samsung TFT Color YP-T7J The Screen Replacement: 手順 14、 2の画像 1 Samsung TFT Color YP-T7J The Screen Replacement: 手順 14、 2の画像 2
    • Insert the new screen into the white unit.
    • Connect the LCD screen to the mother board by inserting the electric ribbon into its port, and closing the lip.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jason Farr
メンバー登録日: 10/21/13
353 ポイント
3のガイドは作成済み
チーム
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G8
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 414
