Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
With your fingers, pry from the bottom of the battery to loosen it.
Lift away to remove the battery from the phone.
Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
Pry around the rear panel with a plastic opening tool to loosen it.
Prying too deeply may damage delicate components inside the phone.
Remove the rear panel from the phone with your fingers.
Locate the flex cable attachment at the tab with a green arrow printed on top.
Pry from the side the arrow is pointing with your fingers.
The cable will audibly snap as it is removed from its attachment.
Let the cable hang loosely to the side of the phone.
Pull the motherboard up from the side opposite the loose flex cable.
If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
Lift to remove the motherboard from the device.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
