この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to detach and replace the phone's touchscreen display.
必要な工具と部品
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
Pry the keyboard away from the casing with the plastic opening tool.
Locate the clamp holding the gold display cable to the back of the screen.
Using the plastic opener tool, lightly pry the cable attachment into an upright position.
Once completed, the attachment should resemble the marked section.
13 の人々がこのガイドを完成させました。
コメント 1 件
Overall this was a great presentation. Very thorough and detailed, yet simple, with great pictures. Thank you.
