メインコンテンツにスキップ
Samsung Solstice Rear Facing Camera Replacement
必要な工具と部品
  1. Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 手順 1、 3の画像 1 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 手順 1、 3の画像 2 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 手順 1、 3の画像 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 手順 2、 3の画像 1 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 手順 2、 3の画像 2 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 手順 2、 3の画像 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
  3. Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: 手順 3、 2の画像 1 Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Remove the back cover by sliding the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
  4. Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 手順 4、 3の画像 1 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 手順 4、 3の画像 2 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 手順 4、 3の画像 3
    • Locate the SIM Card slot directly above the battery and below the phone camera
    • Place your thumb on the SIM Card in the slot, press down gently and slide the card away from the slot, until it comes out of the slot entirely
  5. Samsung Solstice Rear Facing Camera Replacement, Set SIM Card aside: 手順 5、 1の画像 1
    • Once you have removed the SIM card, set it aside from the phone.
  6. Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 手順 6、 3の画像 1 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 手順 6、 3の画像 2 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 手順 6、 3の画像 3
    • Remove the six 0.4mm Phillips screws securing the midframe to the front panel assembly.
    • Grasp the the plastic midframe with your thumb and forefinger and lift it away from the phone.
  7. Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: 手順 7、 2の画像 1 Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: 手順 7、 2の画像 2
    • Use a plastic opening tool to pry the connectors from their sockets on the motherboard.
    • Gently remove the motherboard from the phone
    • Set the motherboard aside once it is free and separated from the phone
  8. Samsung Solstice Rear Facing Camera Replacement: 手順 8、 2の画像 1 Samsung Solstice Rear Facing Camera Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to carefully pry the camera connector from its socket on the motherboard.
終わりに
作成者
1人の作成者と共同作成されました。
Colton Glyder
メンバー登録日: 09/05/14
301 ポイント
3のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014人のメンバー
USFSM-STEWART-F14S1G2
3 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 187
