メインコンテンツにスキップ
Samsung Series 9 NP900X4B-A02 I/O PCB Replacement
必要な工具と部品
  1. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: 手順 1、 2の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: 手順 1、 2の画像 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 2、 1の画像 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 3、 2の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 3、 2の画像 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 4、 1の画像 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: 手順 5、 3の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: 手順 5、 3の画像 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: 手順 5、 3の画像 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 6、 3の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 6、 3の画像 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 6、 3の画像 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
  7. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: 手順 7、 2の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: 手順 7、 2の画像 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  8. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 8、 1の画像 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  9. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 9、 2の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 9、 2の画像 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  10. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 10、 1の画像 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
  11. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, I/O PCB: 手順 11、 1の画像 1
    • Remove the five 2.5 mm Phillips #00 screws securing the I/O PCB.
  12. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 12、 1の画像 1
    • Lift and pull the SSD from the board.
  13. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 13、 1の画像 1
    • Disconnect the black press fit connector by gently lifting up.
  14. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 14、 2の画像 1 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: 手順 14、 2の画像 2
    • Lift the right side of the I/O PCB and pull to the right to remove it from the laptop casing.
終わりに
作成者
2人の作成者と共同で作成されました。
Brady Hildreth
メンバー登録日: 11/04/19
361 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S1-G4, Henning Fall 2019 IUPUI, Team S1-G4, Henning Fall 2019人のメンバー
IUPUI-HENNING-F19S1G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 273
