メインコンテンツにスキップ
Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement
必要な工具と部品
  1. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement, Back Panel: 手順 1、 1の画像 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 2、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 3、 3の画像 1 Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 3、 3の画像 2 Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 3、 3の画像 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement, USB & Headphone I/O Board: 手順 4、 1の画像 1
    • Locate the AUX and USB port on the left side of the laptop.
  5. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 5、 1の画像 1
    • Remove the one 0.1mm screw using a Phillips #0 Screwdriver from the laptop.
    • Keep track of the 0.1mm screws for reassembly later.
  6. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 6、 1の画像 1
    • Use a plastic prying tool to remove the top connector of the port from the motherboard.
    • This should come out very easily and allow access to the Memory card.
  7. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 7、 1の画像 1
    • Remove the second connector from the motherboard using the prying tool.
    • This should come out very easily, and allow access to the Memory card.
  8. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 8、 2の画像 1 Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 8、 2の画像 2
    • Find an opening on the side of the port and pry the USB and AUX port out of the laptop with the prying tool.
  9. Samsung Series 9 NP900X3A USB & Headphone I/O Board Replacement: 手順 9、 1の画像 1
    • Remove and place the port outside of the laptop. You are free to install your new USB and HDMI ports.
終わりに
To reassemble your device, follow these instructions in reverse order. If the replacement does not fix your problem, you may have a motherboard problem that will require a software dignostic.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Zahir Sanchez
メンバー登録日: 02/08/18
493 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S2-G4, Thomas Spring 2018 University of North Texas, Team S2-G4, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S2G4
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 643
