はじめに
Remove if you have damaged the USB , AUX , or HDMI port.
必要な工具と部品
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
To reassemble your device, follow these instructions in reverse order. If the replacement does not fix your problem, you may have a motherboard problem that will require a software dignostic.
ある他の人がこのガイドを完成しました。
