メインコンテンツにスキップ
Samsung Series 9 NP900X3A RAM Replacement
必要な工具と部品
  1. Samsung Series 9 NP900X3A RAM Replacement, Back Panel: 手順 1、 1の画像 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A RAM Replacement: 手順 2、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A RAM Replacement: 手順 3、 3の画像 1 Samsung Series 9 NP900X3A RAM Replacement: 手順 3、 3の画像 2 Samsung Series 9 NP900X3A RAM Replacement: 手順 3、 3の画像 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A RAM Replacement, RAM: 手順 4、 1の画像 1
    • Identify RAM slot on the top right side of the battery.
    • Note that there are 2 RAM slots. It is possible to add another RAM unit to increase performance. (Use DDR3 RAM only.)
  5. Samsung Series 9 NP900X3A RAM Replacement: 手順 5、 2の画像 1 Samsung Series 9 NP900X3A RAM Replacement: 手順 5、 2の画像 2
    • Place your fingernail or a pry tool in between the metal retention bars and the RAM unit.
  6. Samsung Series 9 NP900X3A RAM Replacement: 手順 6、 2の画像 1 Samsung Series 9 NP900X3A RAM Replacement: 手順 6、 2の画像 2
    • Use your fingernail or pry tool to pull outward on the retention bars.
    • If done correctly, the RAM unit should pop upward at a 45 degree angle.
  7. Samsung Series 9 NP900X3A RAM Replacement: 手順 7、 1の画像 1
    • Pull up on the RAM unit at a 45 degree angle to release it from the retention bars.
終わりに
To insert the replacement RAM unit, follow these instructions in reverse. If RAM unit replacement does not solve your issue, you may have a defective motherboard.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Noah Smith
メンバー登録日: 02/13/18
190 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G4, Thomas Spring 2018 University of North Texas, Team S2-G4, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S2G4
3 メンバー
5のガイドは作成済み
コメント 1 件
Thanks for the steps!
Juan Caba - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 59
今までの合計 5,504
