メインコンテンツにスキップ
Samsung Series 9 NP900X3A Memory Card Replacement
必要な工具と部品
  1. Samsung Series 9 NP900X3A Memory Card Replacement, Back Panel: 手順 1、 1の画像 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 2、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 3、 3の画像 1 Samsung Series 9 NP900X3A Memory Card Replacement: 手順 3、 3の画像 2 Samsung Series 9 NP900X3A Memory Card Replacement: 手順 3、 3の画像 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A Memory Card Replacement, USB & Headphone I/O Board: 手順 4、 1の画像 1
    • Locate the AUX and USB port on the left side of the laptop.
  5. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 5、 1の画像 1
    • Remove the one 0.1mm screw using a Phillips #0 Screwdriver from the laptop.
    • Keep track of the 0.1mm screws for reassembly later.
  6. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 6、 1の画像 1
    • Use a plastic prying tool to remove the top connector of the port from the motherboard.
    • This should come out very easily and allow access to the Memory card.
  7. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 7、 1の画像 1
    • Remove the second connector from the motherboard using the prying tool.
    • This should come out very easily, and allow access to the Memory card.
  8. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 8、 2の画像 1 Samsung Series 9 NP900X3A Memory Card Replacement: 手順 8、 2の画像 2
    • Find an opening on the side of the port and pry the USB and AUX port out of the laptop with the prying tool.
  9. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 9、 1の画像 1
    • Remove and place the port outside of the laptop. You are free to install your new USB and HDMI ports.
  10. Samsung Series 9 NP900X3A Memory Card Replacement, Memory Card: 手順 10、 1の画像 1
    • Using your Phillips #0 Screwdriver, unscrew the 0.1mm screws securing the memory card in place at the top.
    • Remember to keep track of the screws for reassembly.
  11. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 11、 3の画像 1 Samsung Series 9 NP900X3A Memory Card Replacement: 手順 11、 3の画像 2 Samsung Series 9 NP900X3A Memory Card Replacement: 手順 11、 3の画像 3
    • After removing the screws, your card should angle upward making for an easier removal.
    • Using both hands, gently lift the card out of its socket in the direction away from yourself.
    • Use caution when removing the card, bending the pins will damage the socket and your ability to reuse the memory card if you plan to.
  12. Samsung Series 9 NP900X3A Memory Card Replacement: 手順 12、 1の画像 1
    • Replace the the card with a new compatible memory card.
    • To install your new memory card, follow these steps in reverse order.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Austin Gross
メンバー登録日: 02/08/18
228 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G4, Thomas Spring 2018 University of North Texas, Team S2-G4, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S2G4
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 28
今までの合計 1,156
