はじめに
Proving once again that thin and light can still be repairable when thoughtfully designed, the Series 9 15" scores a near-perfect 9 out of 10.
  1. Reference shots.
    • Reference shots.
  2. Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off.
    • Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off.
      • It's clipped in along the back edge but not very strongly.
    • Internal view.
    • This is seriously cool. From here we can remove: SSD, RAM, battery, right speaker, display assembly, wireless card, (modular!) headphone jack and thermal assembly.
      • That's pretty much everything you'd ever want to tinker with in a laptop. The only commonly-replaced components we can't reach is the keyboard, trackpad, and motherboard.
    • To keep things uniform, we're starting with the battery.
    • It's held in with seven Phillips screws and comes out in a flash.
    • We then start picking parts off the motherboard and the peripheries.
    • Along the way, we discover room for not one, but two RAM modules.
      • That addition, along with the standard, removable SSD means this laptop is super upgradable.
    • We could remove the motherboard at this point, but pause to take a look at this trackpad.
    • Seemingly held in place with just five screws, but we remove them and it won't budge.
    • Then we peel off this pair of taped-in brackets, pry from the top bracket, and successfully remove the trackpad assembly.
    • Next up is the fan. It's secured with two screws.
    • And the daughterboard. After unscrewing three Phillips screws it will not budge, so we had to break up the adhesive holding it in.
    • Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge.
    • Finally we remove three screws from each of the display hinges and the display assembly is free.
    • The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
      • All screws are Phillips screws.
      • RAM, SSD, and battery are all easily replaced.
      • Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
      • A moderate amount of adhesive on the I/O board and trackpad brackets complicates some reassembly procedures.
      • Manufacturer does not provide user-accessible repair documentation.
ゴール
5 の人々がこのガイドを完成させました。
Evan Noronha
メンバー登録日: 2015年02月05日
152,288 ポイント
176のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
108 メンバー
7,528のガイドは作成済み
how would one repair water vapor trapper in between the touch panel glass?
cooperbeaman - 返信
Sadly when you pulled back the bezel you missed that it’s not a separate LCD but part of the top cover those screws at the bottom just hold a panel in place at the bottom.
Good guide otherwise.
Gaspard Leon - 返信
統計データを表示:
過去 24時間: 7
過去 7 日: 48
過去 30 日: 218
今までの合計 3,772
