メインコンテンツにスキップ
Samsung Series 5 Ultrabook RAM Replacement
必要な工具と部品
  1. Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: 手順 1、 2の画像 1 Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: 手順 1、 2の画像 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: 手順 2、 2の画像 1 Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: 手順 2、 2の画像 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: 手順 3、 2の画像 1 Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: 手順 3、 2の画像 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook RAM Replacement: 手順 4、 2の画像 1 Samsung Series 5 Ultrabook RAM Replacement: 手順 4、 2の画像 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook RAM Replacement: 手順 5、 1の画像 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook RAM Replacement, Remove the Battery: 手順 6、 1の画像 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook RAM Replacement: 手順 7、 1の画像 1
    • Remove the battery from the laptop.
  8. Samsung Series 5 Ultrabook RAM Replacement, RAM: 手順 8、 3の画像 1 Samsung Series 5 Ultrabook RAM Replacement, RAM: 手順 8、 3の画像 2 Samsung Series 5 Ultrabook RAM Replacement, RAM: 手順 8、 3の画像 3
    • Use a spudger (or your fingers) to unhinge the left and right clips holding the RAM in place.
  9. Samsung Series 5 Ultrabook RAM Replacement: 手順 9、 1の画像 1
    • Carefully remove the RAM when both tabs have been fully disengaged.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Javier Jimenez
メンバー登録日: 11/04/19
223 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G6, Harley Fall 2019 IUPUI, Team S1-G6, Harley Fall 2019人のメンバー
IUPUI-HARLEY-F19S1G6
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 16
今までの合計 1,537
