はじめに
The 16 SanDisk is a limited internal memory capability for the Chromebook.
必要な工具と部品
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel using your fingernails.
Remove all the seven screws from the bottom panel.
Remove the single screw.
use the plastic tool to disconnect the WWAN antennas from the board.
After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
2 の人々がこのガイドを完成させました。
