はじめに
Use this guide to replace the keyboard if the keys do not work or jam or stick when they are pressed.
ツール
パーツ
パーツは指定されていません。
Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
Using the J0 Japanese Industrial Standard screwdriver, remove the four 4.5mm screws on the attachments that connect the screen and keyboard, starting on the right corner, then moving to the left corner. There will be two screws on each bottom corner.
2 の人々がこのガイドを完成させました。
