メインコンテンツにスキップ
Samsung SPH-A640 Screen Replacement
必要な工具と部品
  1. Samsung SPH-A640 Screen Replacement, Back Cover: 手順 1、 1の画像 1
    • Press and hold the “End” button until the phone powers off.
  2. Samsung SPH-A640 Screen Replacement: 手順 2、 2の画像 1 Samsung SPH-A640 Screen Replacement: 手順 2、 2の画像 2
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Samsung SPH-A640 Screen Replacement, Screen: 手順 3、 1の画像 1
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
  4. Samsung SPH-A640 Screen Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
    • Disengaging the clips near the hinge may require some force.
  5. Samsung SPH-A640 Screen Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, carefully remove the buttons from both sides while removing the back cover.
    • Note the positions of the buttons. They must be returned to the same positions.
  6. Samsung SPH-A640 Screen Replacement: 手順 6、 1の画像 1
    • Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
  7. Samsung SPH-A640 Screen Replacement: 手順 7、 1の画像 1
    • Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
  8. Samsung SPH-A640 Screen Replacement: 手順 8、 1の画像 1
    • Remove the front cover of the phone using a plastic opening tool.
    • Slide a plastic opening tool along the seam from the hinge around the perimeter.
  9. Samsung SPH-A640 Screen Replacement: 手順 9、 1の画像 1
    • Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
  10. Samsung SPH-A640 Screen Replacement: 手順 10、 2の画像 1 Samsung SPH-A640 Screen Replacement: 手順 10、 2の画像 2
    • Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
  11. Samsung SPH-A640 Screen Replacement: 手順 11、 2の画像 1 Samsung SPH-A640 Screen Replacement: 手順 11、 2の画像 2
    • Using a plastic opening tool, lift the screen assembly from the case.
    • To the best of our knowledge, remove the hinge to free the ribbon cable from the case and remove the screen assembly.
終わりに
作成者
10人の作成者と共同で作成されました。
Geoff Wiggins
メンバー登録日: 02/13/14
1 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-2, Meza Spring 2014 Ohio State, Team 1-2, Meza Spring 2014人のメンバー
OSU-MEZA-S14S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 395
