必要な工具と部品
First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
Note: The bottom 2 are the most challenging to remove.
Note: When reassembling start with the bottom two tabs.
Remove the 2 speakers by gently prying them up.
The speakers are attached with double sided tape.
ある他の人がこのガイドを完成しました。
